Suspension or "Circling" Toy Helicopters
Postby hovermd » Tue Nov 11, 2014 6:57 pm
This post is dedicated to suspension or "Circling" toy helicopters...
A whole series of toys were designed to be hung by a string from the ceiling for play. Some of the first aircraft toys that used this design were Zeppelins.
But, there are quite a few helicopter AND airplane toys made in this design as well.
The earliest versions use a wind-up motor to spin a propeller mounted on the tail of the aircraft. The propeller would have 2 or 3 lightweight plastic blades, often transparent in color. Once wound up, and with a little shove, this rear-mounted pusher prop causes the toy to revolve in a circle, simulating flight.
On some helicopter versions, the main rotor spins.
Still other toys have wheels that are driven by the wind-up motor as well. This feature allowed a kid to play with the toy on the floor or table more like traditional wind-ups.
I'll start the post with one of the more common helicopter examples, the "H-2 Circling Helicopter" made by Modern Toys (Masudaya) of Japan:
Interestingly, Masudaya also made this toy in an "H-1" version, but the original box seems to have stayed the same:
H-1 Circling Helicopter
Note that this example has it's original string still attached.
Re: Suspension or "Circling" Toy Helicopters
Postby hovermd » Tue Nov 11, 2014 7:03 pm
Here's another Modern Toys (Masudaya) of Japan example, the "Navy No. 8" version:
Modern Toys Navy No. 8
Masudaya made at least one other slightly different version that I've seen, the "UR 46."
Postby hovermd » Tue Nov 11, 2014 7:10 pm
Here is the EHN (Emil Hausmann) VX 100 made in Western Germany:
EHN VX 100
EHN also made a green "U.S. Army Rescue" helicopter version.
These EHN toys feature rotating wheels under the skids, as I mentioned earlier.
Postby hovermd » Tue Nov 11, 2014 7:22 pm
Here's the Air Sea Rescue helicopter that was made by Brim Toy in England:
Brim Toy Air Sea Rescue helicopter
Postby hovermd » Tue Nov 11, 2014 7:27 pm
This a really nice HCT 16-C example by Nikko Gangu Kogyo of Japan. I really like the tricycle gear and 4-rotor design:
Nikko Gangu Kogyo HCT 16-C
Nikko also made a similar 15-C example with a different green litho that reminds me of a taxi cab. Interestingly, the original box to the 16-C above actually says "15-C" on the label.
Postby hovermd » Tue Nov 11, 2014 7:52 pm
The inspiration for the helicopters above came in part from earlier toys like the Lehmann 766 Dirigible "Shenandoah":
Lehmann 766 Dirigible Shenandoah
This mint in the box example sold for over $2700.
Postby hovermd » Tue Nov 11, 2014 7:58 pm
For the airplane and jet lovers, here are a couple fixed wing examples...
The jet is by Modern Toys (Masudaya), the older Circling Plane is by Nomura Toys (T.N.), and the single engine prop airplane is by an unknown Japanese manufacturer.
Modern Toys jet
T.N. and Niko Circling Plane
unknown plane
Postby hovermd » Sun Apr 12, 2015 1:42 pm
Here's a later battery-operated Highway Patrol Flying Helicopter made by Nomura Toys (T.N.):
T.N. Flying Highway Patrol Helicopter
Postby alas » Mon Jan 25, 2016 3:00 pm
As for the 'earliest' suspension helicopters etc: you're forgetting the diecast Tootsie Fly'n'gyro, the Britains autogiro and also 'lead' toys - like the Tootsie Zeppelin!
Postby hovermd » Mon Jan 25, 2016 4:12 pm
alas wrote:
The attachment flyngyro.jpg is no longer available
Good point...
The W. Britain #1392 Autogiro box art clearly shows how the toy was rigged to run down a string from two anchor points.
