A Corgi JU-88 Gets "Wellenmustered"
For members interesting in improving and refinishing die cast models
Moderator: Epap
Postby Epap » Sat Sep 11, 2010 10:26 pm
My latest redo of a Corgi JU-88 may interest some members as it depicts an interesting camouflage scheme used in the Mediterranean battles by the Luftwaffe. It's called a "Wellenmuster" scheme and consisted of numerous small and larger squiggled shaped markings, using light blue/gray on the upper surfaces and a dark color on the under surfaces, to create a very effective over water disruptive pattern. I took a Corgi "Battle Of Britain" JU-88A-1 as my subject, which had the wings of an A-4 mark, but the earlier main canopy featuring a single gun in its rear, and modified it by installing a correct two gun canopy from another Corgi JU-88. That done, I huffed and puffed and eventually finished up with a lightly weathered "Wellenmustered" JU-88A-4. Here are a few pictures. First, a shot of the original model, before I went to work on it:Image
Epap
Re: A Corgi JU-88 Gets "Wellenmustered"
Postby Epap » Sat Sep 11, 2010 10:27 pm
Now, a frontal/side view of the redone JU-88A-4Image
Epap
Postby Epap » Sat Sep 11, 2010 10:28 pm
And a side view:Image
Epap
Postby Epap » Sat Sep 11, 2010 10:29 pm
Another picture showing the side from above:Image
Epap
Postby Epap » Sat Sep 11, 2010 10:30 pm
Finally, a picture of the plane's under surfaces:Image
Epap
Postby BWBrown » Sun Sep 12, 2010 4:17 am
That's a wonderful job! I can see why the color combination worked. That particular camo scheme induces epilepsy if you stare at it too long! Thanks! -- Bryan
BWBrown
Return to Refinished Die Cast Models
