More Diecast Redos
For members interesting in improving and refinishing die cast models
Moderator: Epap
More Diecast Redos
Postby Epap » Sat Jul 17, 2010 6:37 pm
Thought I'd add some more pictures of diecast warbird redos or modifications. The first is a Franklin Mint ( CDC Armour ) 1:48th scale F4U that came with no weathering or chipping and red bordered stars and bars when the real plane sported the later insignias---without the red outline. Here's how the plane looks after my treatment:Image
Epap
Re: More Diecast Redos
Postby Epap » Sat Jul 17, 2010 6:41 pm
Here's how a 1:87th scale Japanese Claude fighter looked as I received it. There are major gaps on the spine of the model and the wing roots. Also, they had misaligned the striping near the tail.Image
Epap
Here's how the same model looks now:Image
Epap
Postby Epap » Sat Jul 17, 2010 6:44 pm
This is a redo of a Japanese Tony in 1:48th scale by Marushin. The model came in a bare metal finish with no weathering or chipping. I changed all of that:Image
Epap
Postby Epap » Sat Jul 17, 2010 6:50 pm
Here are two Hobby Master Brewster F2A fighters in 1:48th scale. Both are complete repaints because HM insisted on using overly dark colors on its models. The one on the stand is a well weathered Battle Of Midway machine and the one in the wheels down mode is a duplicate of the same model painted in an early WWII scheme:Image
Epap
Postby Epap » Sat Jul 17, 2010 6:55 pm
This is a Carousel 1 BF-109E-4 in 1:48th scale that has been completely redone as a BF-109E-3 in Condor Legion colors from the last stages of the Spanish Civil War. This required the fitting of an E-3 canopy instead of the E-4 canopy that the model, which sported a typical Battle Of Britain scheme, carried:Image
Epap
Postby Epap » Sat Jul 17, 2010 6:58 pm
Here's a Corgi Russian Front HE-111 in 1:72nd scale that came painted in pristine white on its upper surfaces. I simulated the white flaking off in many areas and added some weathering and staining to give the model a more realistic look:Image
Epap
Postby Epap » Sat Jul 17, 2010 7:04 pm
Finally, here's a Carousel 1 FW-190D that came with very bad mottling---sort of like polka dots on a tie--- and other small faults. My mods, here, consisted of repainting the fuselage sides and tail and putting in new mottling. I also carried over the under surface colors on the leading edge of the wingtips, added some weathering and a bit of staining.Image
Epap
Return to Refinished Die Cast Models
