F-4 Alcock and Brown
Postby norri » Tue Jan 15, 2013 10:58 pm
an attempt at breaking new ground in a restoration.
the one on the right.
disassemble
strip
after paintsrip and wire buff, clean up the castings
tighten up the undercarriage springs, which are always loose
polishing of the empanarge done
mask up for painting
impossible to get a decal to wrap around the leading edge. it has to be painted
assemble with nose and paint to match
decals; this is the tough bit. nothing fits so most have to be made from scratch. not overburdened with reams of paper, so not much room for error............
‘Alcock and Brown’ take 2. my first ever commissioned work
hope the expectations of the new owner are realised, since he paid in advance. Enjoy!
not exact, but about as close as the limits of scale allow
Re: F-4 Alcock and Brown
Postby FETT1 » Wed Jan 16, 2013 5:01 am
AWESOME...maybe try auto pinstriping tape or FROG TAPE....this tape is green in color and is suppose to have a very tight non bleed seal!
After papaint removal do you have a rock type tumbler?I watched a fellow on Utube use this method with HOTWHEELS ...they clean the vehicle outright!
Then polish..
just a few thought's..
JAS
FETT1
Postby norri » Wed Jan 16, 2013 5:50 am
FETT1 wrote:AWESOME...maybe try auto pinstriping tape or FROG TAPE....this tape is green in color and is suppose to have a very tight non bleed seal!
Then polish..
JAS
many thanks Jas. not sure what a 'rock type tumbler' is. i just use a wire buffing wheel to clean up the castings before painting.
Postby diaclucian22 » Fri Jan 18, 2013 5:45 pm
nice piece 8-)
diaclucian22
